Stripped 550 cylinder spark plug thread
ecovandal
Hi,
I've just discovered one of my 550's has a stripped out thread for the spark plug.   Does anyone have any specific recommendations for the repair.   Presumably a helicoil type of insert.   I want to make sure I get the size right for the tapping tool and insert.   If anyone knows the correct sizing that would be very helpful  .... as well as  links to a good kit to do it ( in the states they seem to have a 'save the thread' kit.
Thanks
2 minutes ago, ecovandal said:
Hi,
Thanks
Spud has done a few with a helicoil type ( only a different make I think ) . Its a smaller diameter spark plug I think . @spudulike
I've a feeling he prefers timeserts which are a threaded bush rather than helicoil which are a diamond section wire coil.
I think the 550 will be 14mm by 1.25 pitch but some small saws have 10mm plugs.
The thing to be wary of is that even the 1 diameter length threads may be too long for the spark plug hole so count the threads and see if a bit needs cutting off with a dremel. Also I don't like carrying the 16mm tap all the way through so the helicoil cannot impinge into the cylinder but have not actually had a problem of the helicoil moving.
1 hour ago, Khriss said:
They aint foolproof, used ones off ebay with varied results  🤔  K
I'm no expert and I think I could almost count how many plug holes  I have done on the fingers of my hand and I think only three on chainsaws. I only use the stepped reamer taps for spark plugs but drills and taps for smaller threads,
ADW is of course, correct....I use helicoils or Stainless inserts but would use helicoils on a 10mm repair.
My recommendation - use a decent tap - I use Vokel and I would attempt to use a pilot nose tap as if you have enough thread left, it eases the tap in and getting it straight is damn important.
If you use a cheap crap tap....you may as well save your money and throw the cylinder away now! A helicoil needs a well cleanly cut receiving thread. If it is knobbly rough and poorly formed, you will get poor heat transfer and it may even pull out giving you a bigger headache.
Probably easier to take the cylinder off but if you are precise and catch all the swarf, I have done successful repairs without stripping the engine.
Here is the tap you need (Haven't checked best price). You will need a bit of thread left in the hole to receive the tap but it is your best option.
HSS-G Spark Plug Taps Pilot Nosed To suit wire inserts ISO (6H) Tap tolerance ISO 1 (4H)
Thanks very much.  What sort of helicoil should I be looking at ? ( I know its M10 X1) .  Free running or screw lock, thread length  ...... asking for an idiot !
