Warranty is 12 months from date of sale, however warranty is a fault in materials or manufacture, I would say the melting was due to a bad connection between the cigarette lighter and the adapter causing an arc and heat build up.
Does that tip have a knurled nut with a spring and fuse ?. Thinking if it was a loose nut causing a poor connection then melting the plastic.
