Alternator fault? Not familiar with the machine so only a guess. Check battery condition and connections maybe?
If it's not charging or the battery is knackered it might not have the voltage to keep the system running and shuts down as a result
Hiya mate we had the same problem a few months ago with our 150. And the problem was the control panel. We took our old one to green mech they tested it said that was at fault we got a new one put it on and fired up straight away never looked back since. 👍 cheers.
