Just now, Mark Bolam said:
The thing is, if it was something physical like a blocked filter it wouldn’t return at all, would it?
Each down ‘cycle’ is at normal speed.
Like Dan says, maybe a poor connection somewhere, hence the on/off business?
A new solenoid loom assembley is about a tenner.
Next stop?
Being a transit, I am guessing your controls are on the dash rather than a wander lead?
If so, then I suspect a problem there.
Next stop?
Could then be something simple as a bad earth ?
Yes mate, electronic pad on dash.
30 minutes ago, Mark Bolam said:
How???!!!!
I’ve got jump leads.
If it's an earth problem attach a jump lead to the pump earth, attach the other end of the jump lead to a cleaned up part of the chassis. You've now earthed the pump motor.
I know this is a different bit of kit but the same type of pump. I for tipper trailer. Would raise no prob wouldn’t lower. Tried blipping down and would lower a couple of inches. Turned out to be water in the oil and blocked return filter. Oil had turned to soup. Drained oil and flushed with new. Problem sorted. Might be a blocked return filter?
It could be a filter problem, but returns every time at normal speed, just in 10 stages instead of one.
There is a local hydraulic place, I’ll check what wiring I can then use them if I have to.
The problem is if it’s an electrical problem with the electronic unit in the dash they might be as clueless as me.
1 hour ago, Mark Bolam said:
@dig-dug-dan I lowered it loaded today, euc rings.
It came down pretty quickly in 3 cycles instead of the 8 it is taking empty.
That's pointing towards the same issue I had.
You need to lift the body right up and seriously wd40 those bottom bearings that the ram pins pivot on, then try it again
