1 hour ago, Billhook said:
Bet that a wood burning boiler gives better heat in cold conditions!  Plus being quiet and pleasant to look at
I forecast a hard Winter!
No problems with noise but no denying a stove is far cheaper to buy and instal.
Having both has proved a perfect combination for us. Run the heat pump for low background heat as its most efficient the cooler you run it and top up the heat in the sitting room with the log burner in evening.
saw something the other day on tv they were drilling into a old coal mine and were going to recirculate the warm water out to provide heating for houses then it went back into the mine it did not go into details
Seen snow on the hills behind my house yesterday, we’re not even in the highlands and it’s not even November yet. I hope your forecast is correct, not had a real winter in years.
Water in the underground mine workings of the former Caerau colliery has been naturally heated by the earth, and as a geothermal source of energy, Bridgend County Borough Council is investigating how it could be extracted, using heat pump technology and a network of pipes, to warm around 150 nearby homes.19 Jan 2018
Full moon and clear skies here but outside temp on my window gauge is 6.7 degrees so some way to go yet!
I think that our wood heat here may be slightly different to many as we have an Aarrow Stratford 30kw boiler stove and the main floors downstairs are underfloor with insulation which gives a lower temperature background heat and because heat rises and most people like the warm feet cool head idea, it works well.  Certainly lovely to come into the kitchen with bare feet on warm tiles on a cold day!  So I can see heat pumps working well in a new build with insulated floors and maybe a borehole type ground source if limited by small garden.  Not suitable in many towns I suspect.
The other good thing about underfloor heating is that it acts like a large heat sink and the effect lasts for sometime.
The Stratford has a large glass window so the additional visual benefit when sitting in the same room.
AFAICS there's not much not to like about underfloor heating apart from, perhaps, places that are only occupied for a short while, village halls, scout huts etc.
I was working at a large townhouse yesterday, cutting some ash from the felling of an open grown tree about a year ago, sizes were from 4" to 18" in a neat stack of about a cord. Split faces were about 36% mc on my meter,Took me 4 hours and three tanks of fuel but that won't last their 2 stoves and jetmaster long.
Anyway the house was 50 metres from the gas main and would cost £6k  for the connection so when the new owner moved in he elected for an air source heat pump.
It looked like 4 of those fan-coil air conditioning units you see on office buildings. A bit incongruous on the outside of a Victorian, flint knapped building. I'm biased but thought it looked worse than the 16 solar panels I have on my house.
He did say that he was surprised at how much electricity he was using but wouldn't go into detail, I imagine it was still using radiators.
Definitely seeing more negativity around heat pumps on the web, but I remain open minded as these things are in their infancy and like cars, you may have had a bad experience with a 1960 Mini but a 2021 version is a bit different!
One other factor I might have to contend with is not just the cost of replacing my gas boiler for a heat pump or a hydrogen powered boiler, but also my cookers and maybe upgrading all the pipelines to be compatible with hydrogen  or buying a new electric cooker.  And I love cooking with gas!
Yes but fundamentally they are the same a fridges  so I expect only minor tweeks. They will be "tuned" to give the best result (Coefficient of Performance)  at a given output temperature and temperature of whatever the collector is outside. This is unlike to exceed a COP of three and a bit  most of the time, so if  we ignore the substantial capital and replacement cost with electricity at 22p/kWh the heating won't get better than 7p/kWh. Drop to a delta T of over 20C then what happens?
So it looks like the intention is to let gas rise from the current 4p/kWh (I still pay 3p till April) to above 7p/kWh.
If you accept the grant for a heat pump then you lose your gas connection forever. As to hydrogen; I do not think it can use any current gas grid as it finds leaks much better than methane.
I do wonder why the capital invested in the natural gas network  is not worth  finding a way to synthesise  methane from all this hydrogen we expect and carbon from plants or indeed oil.
With the move to electric cars I think  a domestic CHP becomes worth looking at even if it is internal combustion based I bet the constant running for short periods charging a battery will compensate for the varied conditions a IC car has to deal with  and running on methane it will be very clean plus heat the house.
See above and for the small amount cooking uses LPG will be around for a while.
A decent induction hob should be up with gas for better heat control
Nothing wrong with most heat pumps but plenty of problems with salespeople selling them for totally unsuitable homes. On top of good levels of insulation you need large heat emitters ie very oversized rads or UFH. Heat pumps are way more efficient the cooler they run. Once they start having to heat water to the temps a conventional heating system with rads need the efficiency drops off a cliff. Seems a typical gas boiler will heat your water to 75c. This enables a quick response from small radiators. For comparison out GSHP never has to heat our UFH water over 30C. They are OK to 35C but I am a tight git and if it needs to run warmer and the weather is bitter I top up our house temp by running the stand alone wood burner.
This site gives lots of info about them and this page talks about the efficiency (COP) if a bit over optimistic IMO. Also efficiencies dont take into account running a circulation pump which are on 24/7 in the heating season so even though low wattage its small draw adds up with all the hours it runs.
HEATPUMPS.CO.UK
Heat pump energy efficiency
