Chain Filing Angles
Mick Roseblade
I was just wondering what top plate angles you guys use? Ie 30 deg being a fairly standard angle but do you guys vary either way or choose your angles depending on the wood you are cutting eg hard/soft? I am assuming 30 was chosen as an average to cover general use but I am aware some manufacturers quote 25 or 35. I realise its not critical as long as you keep consistent so I guess my question really is do people bother.
I always sharpen at the recommended angle, 28° in my case, it does make a difference on most chains. It will vary depending if it's full or semi chisel.
Only change I make for softwood is lowering the depth guages slightly.
All my chains are either 25° or 30°, so whatever's specified. Most of them have the wear limit line on the cutter tooth so easy to tell.
Sometimes i file at the wrong angle because i'm an idiot and i stick the magnetic guide on the wrong way.
Edited by Moose McAlpine
