Ms150 problem
Neil T
Sounds like the bar tip sprocket is failing or has been damaged. Best fit a new bar and chain and try that.
Not sure what the "clogging up" bit is! I take it the oiler is functioning OK?
Point the bar tip at a piece of clean wood and rev flat out, it should leave a line of fresh oil in 2-3 seconds.
Edited by spudulike
Put some petrol in the oiler and blow out thoroughly to clean and then test to make sure it’s flowing.
I worked at one firm where 4 of the 5 had the problem you describe.  The 5th one had an exhaust mod.  It never got clogged.  My theory is that the mod either gives the saw a bit more torque and/or chain speed.  Either way, it seems to clear the debris better when compared to standard.
I have 2 150t’s that have been modded and they rarely clogg up in the same way.
