1 minute ago, trigger_andy said:
You put the logs on the mill when its parked up Leslie :D
If you played it right you could have the mill be demountable so that you could use the trailer and crane for collecting logs.. 👆
Then it would no longer be close to 2t would it? :D:D:D
4 minutes ago, topchippyles said:
A man like yourself should know his limitations 😉
You should look in the mirror a bit more frequently Leslie You might see what many of us here do.....
Yours would crack into a thousand pieces 🤏
  • 1 month later...
Hi  All ,  With hindsight are there any  changes to the specification or build you d alter , or is it spot on .
Im interested in a Trakmet and im trying to get an idea of whats needed ?
First post by the way .
