McConnell PTO bench spares
Acerforestry
I would find it odd that there would be anything unusual about belts for a MaConnell sawbench?
If there are no belts on there try a few random marked belts to establish the correct "V" section/profile, then measure around the 2 pullies with a tape.
There should be plenty of room for the adjustment of tension, which gives wriggle room length wise, but check if the adjuster is at the stops, and which way!
Then look online.
There are a couple of really good sites/companies.
Sorry if that sounds a bit like teaching granny to suck eggs.
mth
There will be belts on the bay for that as there is a company that i use for odd ball belts, just measure the outside length of the belt, drop down box on add with length and v width n depth, just select and will be generally be there 2 days later,
If its the flat belt you are after you cannot buy from McConnel anymore, but we have a contck who makes them, i'll dig the number out in the morning, if it's the V belts as many have said you can get anywhere - If you've flat belt and want to make life easier we keep V belt conversion kits in stock - this replaces the pullies and taper locks and converts to a more modern V belt
Give us a call if you like 01584711544 -
