1 minute ago, Khriss said:
Its yr friday night ☺️ you just go fr it 😋 K
3 minutes ago, Baldbloke said:
I now have visions on having to remove the the air filter to give the inlet manifold a blow jobemoji12.png
Get the mrs on it 🙄
This thread has taken a disturbing turn in my absence.
I have just come in from bending up a new wing for mine. I know I know, unnecessary expense but the bottom part would no longer hold the accelerator bar in place and I can't get the weld to stick to the rust for some reason. I could have just built it up in MIG wire or welding rod, but in the end a bit of steel was cheaper and quicker. I am alternating between that and welding the front wing on my wife's Midget (I weld, she grinds it all off again...) and the latter is definitely more complicated. I wish she would settle for the same shaped wing as the one on the back of the dumper!
Alec
Alec
.... You need to get out more 😉 K
I will, as soon as I have a vehicle to get out in. Now do I go for the Midget or the dumper...
Alec
Alec
Dumper, cant get nicked on that if yr pissed 😉 K
( or buy a Series Landrover..............)
There is a Series 2 in bits which is making slow progress - this weekend will be topcoating various things black if the weather holds. There is a 2a in the shed in need of the gearbox taking off to sort the clutch, oh and a bit of welding on the chassis rails and outriggers, and the oldest known S2 109" Home Market Station Wagon is currently residing in my garden (not mine but I have the keys).
Is that enough Series Land Rovers do you think?
Alec
