Cut the top and bottom off . Make sure they are reasonably clean . Then fit them inside each other when they weigh 1000 kg which is a hell of a lot of plastic liners take them to a trade waste tip/recycling centre they will charge £95 per tonne and take them from you . Don’t buy ibc with nasties in them water soluable or fruit juices ad blue etc are ok
Edited by gensetsteve
No need if you cut them like I suggested . You get two lids and nothing to dispose of .
2 hours ago, trigger_andy said:
Think about what you’ve just wrote. 🧐
You guys really don't get it do you ?  Andy . Get a cube of cheese . Lay it on the cutting board . Now place your knife on the upper most surface with the blade lined up from corner to corner . Push down cutting it in two .  Now you have two apexes , roofs , lids , whatever you want to call them and nothing else .  Now cut the IBC liner the same way .
Edited by Stubby
I don’t need that many lids and 500 ibc tanks cut in half take up a lot of room 😄. I just cut the top 6 inches off and use that for a lid less height and less eyesore . I have started cutting the sides of the tank into 6 in strips and using this as labels on the side of the cage threaded through the bars
Exactly. This is exactly what we do get.
Now you yourself have just stated that you'll have two 'roofs' . Two roofs from each IBC Plastic Liner. So two 'Roofs' from one liner, and how many 'Roofs' does one IBC need?
Think about it. ;):D :D:D
I think outta respect for you the others are just pretending you've not been repeatedly forcing this line of reasoning. :D
Edited by trigger_andy
Then eat the cheese so its not wasted. K
Edited by Khriss
He doesnt get it Mr Stubby, thats exactly how i make my ponds so there is a deep bit in middle.
AND NO WASTE TO DISPOSE OF > 😁
