How much should it cost to have this tree and roots removed and stump ground?
I think you've posted this in the wrong sub-forum. You might get more responses in the General? Or even follow on from the thread you started on that tree earlier?
But I think the responses you'll get will all be along the line of get three quotes from reputable local firms and see what they quote.
Edited by trigger_andy
Can't comment on the cost of this but if you could give more detail/pics of the situation it'd help others.
What is in the area around the base of tree, how close can the equipment get, what is the access like (width of gates/passageways) is the type of thing that may help
5 minutes ago, Con said:
A little bit more than it would've done before the best rigging points were removed
Same !  .Its a bit like when the customer says I have removed and cut up all the thin bits . You find a pile of brash  all pointing this way and that and not one bit long enough to go in the chipper with out having to poke it in with a plastic shovel !
Can you not forward this to your fellow country man, he has got a big Jigsaw for this type of work 😂😂
