Does anyone use a winch on an Avant loader. I have looked the Avant winch which is a 1 ton winch and was wondering firstly if anyone has one and is fo what are your thoughts on it?
Also wondering if I could maybe get a bespoke winch with a greater tonnage rating and is anyone has already done this?
Ta
I’ve seen them on Instagram a bit. Seem ok but not earth shattering.
I think the Avant loader (depending on size) already has a very decent pull, so if it’s just for persuading trees over that usually does it.
I opted for a petrol powered winch so I didn’t have to drag the loader around just to get some pull on site.
Edited by Mick Dempsey
Thanks Mick, Yep its for that but I have found a few times now that because of the way the loader moves in reverse if you get out of shape you can end up with a problem on your hands. I like the thought of just sitting still and letting the winch do the work. Yep seen them too and thought the same really. Worst case I will buy an Avant one but I know already that I would like a more powerful winch.
Edited by Chipperclown
If only to pull the odd tree on jobs, why not rig a 12v winch and a frame with an anchor or have it on what ever attachment you use with a couple of good pins and connect it to battery with anderson plug.
Edited by woody paul
Got a 5 T Warn on my Cast loader, I Mounted it on a  plate & just close the pallet forks to lock it in place, it’s pulled some big trees over & the forks make a good anchor
  • Like 21
