I’m sick and tired of the stress of running over weight transits, it’s not fair on the lads either to expect them to do so.
Planning on getting a 10 or 12 tonner with a hiab, the only thing that I’m just finding impossible to find out is how much can I tow behind a say a 12 lorry??
Thanks in advance
Thanks in advance
Expand
You will need something already piped for air like a wagon and drag if you want the big train weight or you will be limited to something on overrun brakes. There are a few SWB wagon and drag units about that would lend themselves to ARB work.
Jenkinson  run them
These trucks are out there, we used to run a 10 ton Daf, that had a five ton payload and could tow 8 tons. As I mentioned it needs to be piped for air or you have the ballache of getting the air conversion approved and the plated weights altered.
Bob
Bob
That sounds like a good set up! Would be nice to drag a hooka lift trailer or something of the sort behind it
Thanks in advance
Expand
That's a hell of a leap from transits, but if it works for you best way to go.
Is it though?? A 7.5tonner is only a down rated 10 tonner. Get a nice sized hiab on that.
After a while it just becomes to much of a headache trying to keep up with transits, they become a bottle neck, you’re always overloaded and it’s unfair to ask lads to drive them over loaded all the time.
Expand
Only some of them.
Take Iveco for example, a 75e something v`s a 80e something, the latter is a factory down rated 10 tonner, or a heavy duty 7.5 tonner if you like.
Most 10-12 tonners are not much bigger than a 7.5, some can be based on 15 tonne chassis so a bit wider again.
Read more
