  • Replies 52
u be suprised how heavey pine is freshley felled just how i seen it written down mate
i know all the years i sent lorries away with large scotch and corsican i was always surprised how they got their weight with big sawlogs,lorry looked half full,just surprised twice as much beech would be the same weight.i usually reckon about 30 cubic feet of beech to the ton so sounds about right :001_smile:
hope this some use as there is a lot of different ideas people have about weight and m3 it from foresters companion book my bible oldschool:001_smile:
softwood green weight cubicmeter weight conversion
pine=m3=1.98 tonnes
larch=m3=1.20 tonnes
dougfir=m3=1.15tonnes
spruce=m3=1.04tonnes
Hardwood green weight cubicmeter conversion
Beech=m3=0.97 tonnes
Ash=m3=1.28 tonnes
oak=m3=0.94 tonnes
Average weight of seasoned timber 15%moisture content
pine=m3=600kg
larch=m3=500kg
dougfir=m3=500kg
spruce=m3=400kg
hardwoods
Beech=m3=720kg
Ash=m3=700kg
0ak=m3=740kg
u made some mistake there mate.........
green pine oak and beech are much the same around 1 cubic metre to 1 tonne
green stika 1 cubic metre is around ..........0.97 tonne
hi david the greenweight figures was from the third edition of N.D.G james the foresters companion that i borrowed of the old woodsman i own the forth edition cost me a small fortune of £90 as out of print that had the 15%moisture chart forth edition didnt have any mention of the green weight,a real shame there is no books as good as this any more
Because it was wrong in the third edition maybe or you are interpreting it wrong :001_rolleyes:
Is green pine ~2/3 water or only ~200kg lighter than dry concrete, I think not ;)
If standard density is 1 = 1000kg per 1m3 then the green figures could be a division factor of 1 / X = Y * 1000 = Zkg
“pine=m3=1.98 tonne”
1m3= 1 / 1.98 = 0.5085kg = 505.8kg per 1m3
(600kg dry)
“larch=m3=1.20 tonnes”
1m3 = 1 / 1.20 = 0.8333 = 833.3kg per 1m3
(500kg dry)
“dougfir=m3=1.15tonnes”
1m3 = 1 / 1.15 = 0.8695 = 869.5kg per 1m3
(500kg dry)
“spruce=m3=1.04tonnes”
1m3 = 1 / 1.04 = 0.9615 = 961.5kg per 1m3
(400kg dry)
“Beech=m3=0.97 tonnes”
1m3 = 1 / 0.97 = 1.0309 = 1030.9kg per 1m3
(720kg dry)
”Ash=m3=1.28 tonnes”
1m3 = 1 / 1.28 = 0.7812 = 781.2kg per 1m3
(700kg dry)
“oak=m3=0.94 tonnes”
1m3= 1 / 0.94 = 1.063 = 1063kg per 1m3
(740kg dry)
if you then look at it the “pine=m3=1.98 tonne” vs. “1m3= 1 / 1.98 = 0.5085kg = 505.8kg per 1m3 (600kg dry)” is the only figure that falls short of dry weight due to the “1.98” being an error.
these are the figures weve used when processing hardwoods for firewood, especially beech into log form - people think you can get more than 1 - 1.5 cubic metre per tonne but you dont when youve logged it all up. - i think some of the people whove bought in timber at 26 tonne lorry loads will soon realise its harder to achieve those margins as they think theyll get more cube out of it.
