ChainsawAl
Nuts to hold the chainsaw bar
I have a 2 series Husky with one Husky nut and one local hardware store wing nut so probably standard threads
Share this post
Link to post
It's a Titan TTL759CHN 40cm 40cc
Cheap make I know, that's why I was wondering if they would be the same. As I see Stihl and husky do some but not sure if theu are different sizes.
@nepia ah ok cool,I'd imagine they would be,
Share this post
Link to post
Chances are it will be an M8 thread so any of the stihl/husky ones should fit. You can measure the thread sticking out, if its outside diameter is between 7-8mm it will more than likely be an M8
Share this post
Link to post
3 hours ago, KWarb17 said:
#captivesprocketnutsarethebest
I don't think they're that great. When i put the HD clutch cover on my 572 i lost the captive nuts option but M8 flange nuts have worked fine for a long time.
2 hours ago, Mick Dempsey said:
Yes they are but they do get lost, a 13mm m8 is a standard anywhere though.
And easy enough to carry spares in the toolkit.
Share this post
Link to post
Ah but your talking husky ones😄
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
