  On 03/01/2021 at 10:45, Rough Hewn said:
Check the round plastic wheels are good.
I’ve broken a couple.[emoji849]
Also yiu can’t use twine, you’ll need the proper Logosol stuff.
Trust me, I’ve tried about a dozen different polyprop strings, all broke.🤣[emoji106]
The logosol twine is incredibly strong.[emoji106]
The saw carriage is an optional extra,
I’d recommend one.
[emoji106]
I thought this was the saw carriage? How do you use it without it one...IMG_7550.jpg
Expand
Normally comes with the saw mill but you will need that unless roughy knows better. That attaches to the chainsaw which then mounts onto the mill
  On 02/01/2021 at 22:23, Rough Hewn said:
Spend a bit of time with a spirit level and right angle.
When it’s all setup, with a log on it.
Check everything again.
I had an issue with the raisers.
Need oiling occasionally, or they’d stick.
Have you seen the m7/m8 videos?
Loads of really useful stuff from Logosol
Expand
I can see this taking sometime to get things level on that top face....
  On 03/01/2021 at 16:13, topchippyles said:
Can you put down a concrete pad
Expand
It will be on a cow yard concrete silage base.
Was poking about this afternoon but could see frustration levels and cold fingers getting the better of me...
So came inside for a warm snooze in front of the log burner 😅
Expand
Take a few of those slabs up and put a level concrete pad down and bolt it to floor
Two pieces of 4x2 laid down and levelled. [emoji106]
The log weight will hold it all in place.
The saw carriage is just a carriage.
That’s all I have. I push it with a stick.
The winder and bar tip holder are extras.
Expand
Come on saul a nice concreate pad if you have the place to do it is much better. Is that why they call you roughy 🤣 Sorry could not help myself
Read more
