Big dowels
gobbypunk
1 hour ago, forestgough said:
those veritas power tenon cutters go up to 2inch, probably take some holding though,the inch ones will spin your arms off when they catch.
 they kill drills to.
Electric drill with speed setting low is not to bad, but agree when it catches you definitely  know about it.
Or old school hand
brace.
19 hours ago, Jamespepperpot said:
WWW.AXMINSTERTOOLS.COM
These are indispensable tools when it comes to making rustic furniture, where there is a necessity to produce clean...
I wot i thought he meant - pic of yr intended job @gobbypunk ?  Forstener bits are not as directionally accurate as those dowel cutters in deep cuts, but do roar out the wood. K
Edited by Khriss
These cut round tenons, you would use an auger bit to cut the round mortise for them. A forster wouldn't work unless you were using a jig to hold the drill at the perfect angle as, like you said, they are not directional.
