Hurray  having given our mate a good send off yesterday I now have a free few days to build up my new mill it seems like am age since it arrived not sure how I am going to manage as the saw head is sooo heavy but I am sure I will really quite excited and I have a butt of brown oak to go first I think ,I am thinking about going for a bounce back loan to get a forklift and a truck/lorry if I can ,I will keep you all posted
Cheers Mark
Congratulations mate,
My advice is cut a few test logs to fine tune the setup.
I’ve buggered up some lovely logs by not testing my new mill properly???[emoji106][emoji106][emoji106]
Hi mate yep good plan I have half a butt of monkey puzzle ,but according to Chris at woodland mills when I was bitching about not getting any free bands to dial the mill in with its all set up in the factory and it has come with a band fitted so we will soon see
Yeah it does come with a band fitted for sure but I found that changing to Ripper37s necessitated resetting the tensioning wheel to hit the sweet spot ie good alignment at the correct torque setting. It’s easy enough now but the first time it did my head in big time. If you know anyone local who has the same mill I’d see if they will give you a rundown. Not seen the newer models that may have something factory fitted, but I also made an adjuster to help align the motor if tensioning the drive belt.
Um I do need to order some rippers but I think that the tension is made easier on the new models like you said it did my head in on my old hm130 so hopefully I will be ok
So started to assemble my mill today and I have treated 8x2 bearers for the feet and these bearers will sit on my concreate yard ,do you guys think I should put a bracket or screw them down  to stop them sliding as I roll a log up onto the mill or do you think the weight will keep it in place
Cheers Mark
Cheers Mark
100% yes. Even turning a big log will most likely move the mill around. And As you've got the Max then I'll assume thats gonna get pushed ever once in a while.
Hi Andy thanks I was kinda thinking that myself but its always good to have another opinion I have some anchor resin and some 6inch brackets jobs a good un ,so looking forward to finally getting my mill up and running ,but loads of things keep delaying me off to collect a big Walnut butt this morning.  Happy Days
Cheers Mark
Thunder bolts - predrill the timber, then masonry drill through the timber into the concrete - impact wrench Thunder bolts straight in !
Thats what Id do as well.
