Anyone experienced this awesome combo binding in the thicker cuts especially on Willow when a little worn ? (The bar/chain, not the Willow!)
Don’t get me wrong, I’m delighted with this setup and cuts impressively quicker than the 1/4 050 option supplied on the later models , but very quickly the chain seems to bind despite diligent sharpening with 3.2mm file with guide and my best most pub glass thickness-est reading specs [emoji165] [emoji851]
Dressed the bar, turned the bar etc.
Discuss ...?
Sorry to derail thread, but sort of relevant here - anyone else find the 2511 gets its air filter clogged with water in heavy rain? I love this saw, interested in this chain/bar upgrade option.
Don’t get me wrong, I’m delighted with this setup and cuts impressively quicker than the 1/4 050 option supplied on the later models , but very quickly the chain seems to bind despite diligent sharpening with 3.2mm file with guide and my best most pub glass thickness-est reading specs emoji165.png emoji851.png
Discuss ...?
Same.
Couldn’t work it out.
Binned it and went over to the Stihl 150 bar with 56 DL chain.
Sorted.
I think it would be the same Panther bar and chain I put on my Makita, not found a problem but then haven't tried forestry like Mr B in France.
I have found the file guide doesn't guarantee the file height the same on a 3.2, ended up without any hook after a bit (I think because it can bend up) so periodically freehand out the bottom of the tooth. I haven't tried a 4mm file.
Those 3.2 mm files are a pain. They just flex as you sharpen.
I had the panther bar but the nose of the bar came apart. I contacted chainsaw bars, they asked how many chains I’d run on it. Around 4 or 5 was my thinking. I was told that’s about how long they last..... that’s a bit too consumable for my liking so I replaced it with the sugihara 1/4 bar. That ones still on it’s first chain so couldn’t comment further.
Does the Stihl bar fit or does it require the drill ?
Fits straight on with the Stihl 56 drive link chain, no drilling required.
0.43.
Smoothest combo I’ve found as well, love it.
