11 minutes ago, eggsarascal said:
You've got enough mouth on you Les, prove what I've said is wrong.
The only thing Les has proved is what a plonker he is. :D
Still waiting on him posting a single picture of something he's actually made out of wood. Other than sanding two planks. :D :D:D
That'd almost slipped my mind, a month or so back he was 'popping' out to get some pictures of a porch with the stairs in the background he'd made and installed in his mates house for less than £2k.
Yeh, still waiting on that pic as well.
  • 3 weeks later...
So back to my big Wadkin the rise and fall doesnt work right I have removed all the bits of crap wood that was stuck ,sprayed all sorts of lube greased everything and it still woulnt work have any of you dismantled one
  • Sad 1
Large hammer and gas axe always works
Is it a manual or electric fall mark ?
19 minutes ago, gobbypunk said:
Hi mate its both it has a switch for rise or fall and a big wheel on the side I was wondering if when its pluged in will the rise and fall work
My wadkin is a manual using the wheel so have you tried that option mark ?
Edited by topchippyles
