Hi have an issue with fuel leakage from cap!
Thought need a new cap! but got the 372 up and swapped caps over not leaking on 372 but is still on 346 wtf will have another look later and see if can clean anything that is stuck around hole i did clean seal  and area but won't hurt to do again before i boot it out of window!!!
On another note how do you tell if a 45cc or 50cc? mine don't have a decompression button or fuel blob running. 325/058 and how much compression would you feel turning it over by hand ? don't feel massive for sure but it does run well once fired up and cuts well even with rakers skimmed down a fair bit
No Decomp and no primer plus Orange side cover wopuld indicate 45cc.
Check threads are good and inspect fpr cracks around opening
Orange top cover clips, no primer, 45cc
Grey clips, primer, 50cc
Some of the NE 346 50cc did come with orange clutch covers too. So not a 100% sure fire tell tell.  One dealer that sent me this one had like 5 come in with orange covers.
NE 50cc pic
Edited by Cut4fun
2 hours ago, billpierce said:
5 hours ago, Stubby said:
I thought the oil filler was smaller ?
Fuel is the same though
Yea . That's why I said oil filler Bill ?
NE 50cc pic
I was gonna say about that but thought it might get messy .  Also there was the one with , I think orange clips , orange side cover but with an auto de comp and being 50cc .  I had one . Took the pipe off , crimped the connector and fitted a blue, no it was grey decomp .
