TREE SHEARS
,so which 1.
just checking the inter web didnt realise there was so many on the market & differant versions.
so whats good & whats not
JUST TO ADD FOR A 2,5T MACHINE
tia
Got OMf
works for us. Thinks it’s a TMk copy, bought them for a one of Job and thought never going to use these again,
use them all the time now, great for brambley thorny ditch clearance where you can’t get in with flail
47 minutes ago, kevinjohnsonmbe said:
Do you want cut & hold or just cut, rotator head or fixed?
EXAC1 have good kit:
WWW.EXAC-ONE.CO.UK
Tree Lopper A CUT ABOVE THE CONCEPT Tree Lopper is a range of tree shears designed to suit excavators from...
Ive got the tree shear variant - useful piece of kit.
Cut & hold would be better
I didn’t want cut & hold.
On a lightweight, narrow base machine, I didn’t want the potential to topple it. Plus, the cut only function came with a rotator which is useful for higher topping cuts. Appreciate it’s horses for courses and you know what best suits your needs. ??
We got  Farma 180 shear grab about a year ago. Use it on Valtra/botex or 3ton digger.
For what it cost it justifies itself mostly as a ‘tiltable’ grab for grabbing standing stems, holding/sectioning down stems,holding/easing down small to medium trees. Great for taking tangled Leylandi hedges apart .
pretty good for feeding chipper ( not as good as brash grab but better than log grab) great at crushing forks.
Have only used a couple of times with  blade on. Takes a bit of practice to get a feel for what it can and can’t cut.
has exceeded expectations really but will probably go for Jak 200 or similar at some stage
AC price sell the nisula tilt grabs and think they have one reduced at moment, only problem with these is they are very long when tilted so a 2.5 struggles to lift high enough to work close inDSC_0490.jpegDSC_0486.jpeg
This is a jak 250 on a 8t bobcat and you can see how long from end of dipper to blade it is, yes it's very manovarable and excellent at stacking but got to be out a bit or drags on ground, few mods I have in mind to help with this eventually.
