  • 3 months later...
On 22/09/2025 at 20:50, slack ma girdle said:
The poor old Log Bullet has been feeling neglected of late, so what better way of resolving this than steep ground and dreadful access.
#Dullasditchwater
Does your crane struggle to slew with a load on even slightly steep ground? Mine does.
Most cranes struggle slewing with a load. Bring it in closer, and use the rotate to get it moving in the right direction before you start slewing.
Just too used to a digger which never struggles!
This is why forwarders got levelling rams tor the kingpost mount. The slewing is by rams working a rack against a  smallish diameter ring gear, poor torque but if it's level and the load in free air no problem. My cranab 4510 exerts a fair slewing force  for dragging long lengths but fails if it is not level, even with four 4" rams acting on the ring gear.
A digger has a motor with a small gear working on a large diameter ring gear doesn't it? Big mechanical advantage.
  • 5 weeks later...
Jo has reciently started climbing for me, and is proving to be quite adept. Awkward tree with no central tie in, and a large Chicken of the woods bracket at the base.
Edited by slack ma girdle
On 27/01/2020 at 20:04, slack ma girdle said:
My latest humble offering. I have been off work for the last month with a mystery virus, and about all i can do is sit and edit videos.
Have you been tested for Epstein-Barr virus?
That wiped me out last Summer for 4 months.
