I never known what is best from lidl  sunflower or rapeseed used both as think price is same,,,,
I did look up viscousities at different temperatures....
Dunno if it is important.....
Isn't rapeseed oil the only veg oil that doesn't cake when left for a while, hence its use?  I've used it for years without issue but haven't tried any other veg oil.
Rapeseed/Canola has antioxidents naturally. So it's less likely to oxidize compared to some other bio oils, and a healthy choice for cooking with ;). Many bio oils have tachifiers added. In the UK and here in Ireland, it really doesn't get hot enough to need them unless you are averse to sharpening your chains.
I say I work on an estate, but it's really more like a cattle and fishing ranch. I try not to pollute the environs with mineral oil if I can help it. It also saves a huge amount of costs.
Edited by wyk
I've tried sunflower and veg oil neat and mixed 50/50 with bio oil and normal stuff.
It's all fine up to about 16-20" bars. After that I get hot bars. Useless for milling with as it gets really hot and smokes.
Not tried rapeseed oil.
[emoji106]
Just make sure the oil doesn't dry or get sticky when dry. A small issue for the owner but a bloody great big one when it comes to maintenance and cleaning the stuff off.
Early bio oils were a mare.
