What i do with mine is to cut the biggest square beam out of each piece possible as can then be milled into 4x2 6x2 8x2 ect ect or custom cut beams to order.You have the same mill as me and how i mill to maximise the log is to say example. Yon have a 20x20 beam on the mill i wind up the blade a full inch above to a full 21 1/8 and place all the outer edge cuts one by one on top of the 20 inch beam and run each peace in 1 inch slabs so you will end up with 14x1 down to 4x1 boards when square cut. All the waste goes for firewood and sawdust for bedding ect. That is my own self taught milling method. Interesting to see how you guys do it. Happy new year all by the way ?
Edited by topchippyles
1 hour ago, Big J said:
Hmmmm, hard to know exactly. Big douglas is always nice, but the longer you leave it, the harder it will be to cut. Once dry, it's no fun to mill!
I'd personally be inclined to mill them into standard beam sizes and wait for folk wanting feature, non structural beams. You could get them visually graded, but that would probably not be cost effective. It's a nice, strong timber, but not enormously durable.
You could do chunky garden furniture, but make sure you have a market for it first.
Cheers J
To tell truth it’s at the bloody hard work to mill stage now. Probs gonna mill it up to like you say the standard easy to use and produce sizes with maybe a couple of larger ones and see what comes from that.
Having looked online there is a potential end retail price of £800m3 once sawn to 45mm waney edge and kiln dried .
how quickly they sell though I’m not sure
1 hour ago, topchippyles said:
What i do with mine is to cut the biggest square beam out of each piece possible as can then be milled into 4x2 6x2 8x2 ect ect or custom cut beams to order.You have the same mill as me and how i mill to maximise the log is to say example. Yon have a 20x20 beam on the mill i wind up the bladed an full inch above to a full 21 1/8 and place all the outer edge cuts one by one on top of the 20 inch beam and run each peace in 1 inch slabs so you will end up with 14x1 down to 4x1 boards when square cut. All the waste goes for firewood and sawdust for bedding ect. That is my own self taught milling method. Interesting to see howwyou guys do it. Happy new year all by the way ?
Example of what i have tried to explain how i will mill most of my logs. Just a quick sketch as had a couple of pms. I cut the centre to a finished size beam and all the outer into inch boards which gives around 80% of the log for £££
Sorry just to add when milling the outer edges into inch boards i never move the blade up or down. Just rip through move the cut board and rip again and just keep repeating process until finished. Great waney edge boards so maximise profits (firewood) ton bags for all the loose stuff £40 a bag which pays for the next load of uncut logs or helps towards cost ??
So guys how long is too long to leave D Fir before it becomes hard to cut ,a matey of mine has left a pile of logs in the woods for about a year and now wants me to mill it for him ,is a year too long ? I think you are going to say yes it is but thought I would ask those with more experience than me
Thanks Happy New Year.   Mark
Not a problem if its been stacked outside just crack on and mill it
I’d go waney edge cladding - people always seem to ask for it and it’s hard for people not in the know to source . Cut it all the same size to make storage easy - never underestimate the importance of storage. It doesn’t matter if it’s the best timber , milled perfectly - if it’s not stored correctly it’s worthless.
