I was having a little think about chain speeds in relation to my initial question about going with a .325 or a 3/8 chain over the last few days and sat down last night to work them out.
Basing the calculations on the quoted max power engine speed of 9600rpm
A .325 chain with a 7 tooth rim has a chain speed of 18.49m/s
A .325 chain with an 8 tooth rim has a chain speed of 21.13m/s
A 3/8 chain with a 7 tooth rim has a chain speed of 21.34m/s
A 3/8 chain with an 8 tooth rim has a chain speed of 24.38m/s
11 minutes ago, peatff said:
How does pitch affect chain speed?
It's the length between the drive links essentially. The chain speed should be distance between drive links x no. Of teeth x engine speed/60
Thanks for that info.
Thanks for that eye opener, had blindly believed chain speed was function of engine speed and no. of teeth on sprocket. But now  you come to mention it ....:thumbup1:
I hadn't appreciated the difference between the chains.
I know in the real world a saw with a .325 chain may well end up holding higher rpm in the cut than one with a 3/8 chain, but I thought it was really interesting when looking at 7 pin and 8 pin sprockets vs different chain pitches.
Where did you get the 60 from? I ain’t much use at maths, so not questioning your method, just curious.
Engine speed given in RPM, chain speed in metres per second.
