I need to fix 4 10mm bolts (threaded bar actually) into a thermalite block wall.
I was going to drill 12mm holes but my mate said to go bigger as the holes won’t hold enough resin.
How big should I go?
Thanks.
Your method of fixing will depend on the load on the bolts and type of load, shear pull or compression. Thermalise have little strength socare should be taken
In theory you could have your cannon leaning up against a wall  with a hungry Rottweiler sat in front of it . I think it just stipulates kept secure .
You can get cages for the resin anchor 16mm hole the fob of anchor place cage in hole fill with resin place cap and press 10mm stud in cap keeps stud in position
