Sign in to follow this
celi
Husqi 346XP wont start after cleaning carbureta
Hi,
Im looking for some advice please, My 346XP was left over the summer with fuel in, and when i started it last week it wasn't as powerful and kept cutting out. I read that this could be a dirty carbureta after sitting with fuel. I have now cleaned the carbureta, careful to put the limiting screws back in the same spot, but when I put it back together I cant even get is to fire up with the choke on, let alone get it running. any advice welcome.
Thanks
Celi
Share this post
Link to post
What was the position of the h and l screw? Have you definitely put all the gaskets and diaphragms back in the correct order? Is the metering arm set correctly? Is the impulse line ok/clear/leaking air? Is the primer priming?
Share this post
Link to post
Thanks for quick response, this model doesnt have a primer bulb, L was one full turn out, H was 3/4 turn.
I was pretty certain about the gaskets and diaphrams, but will go back and double check them all.
The metering arm could be wrong, is there somewhere you no of I can view the correct set up for that?
Is the impulse line (thats the fuel line right?) likely to have been distrubted whilst I was doing the carbureta?
Share this post
Link to post
The impulse line is the small " c " shaped line that goes from the carb to the crank case . This makes use of the alternate pressure / vacuum created by the piston going up and down .
Share this post
Link to post
IMAGES.APP.GOO.GL
Found on Google from ransomspares.co.uk
Metering arm should be in with the spring and the top of arm level with top of carb. Id double check all diaphrams and gaskets are in good order and correctly installed
Share this post
Link to post
 So the metering arm was wrong, I have now set it correctly, but still having the same problem!
The only line going to the carbureta is the fuel line, there is the C shape line that goes to the flange on this diagram
WWW.RANSOMSPARES.CO.UK
Husqvarna 346 XP (2001-06) CARBURETOR & AIR FILTER Chainsaw Spare Parts Exploded Diagram
, but I wouldn't have touched this or gone near it so my feeling is its unlikely to be the problem.
Share this post
Link to post
Think ADW is correct and for the record, the impulse line fits between a union on the manifold clamp and connects to the plastic surround the carb screws in to and is cock all to do with the fuel line.
Normal errors are metering arm spring fitted incorrectly and gaskets fitted in the incorrect order.
You can pressure check the carb to check the metering arm operation but suspect you don't have a pop off gauge or mityvac type pump.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
