Have a 560xp after someone recommended it if it broke tomorrow i would go straight out and replace it. Put a sugihara bar on it and it runs sweet. Only little issue can be a pain to start when hot.
I have a 2014 560xp, has been faultless. 18" bar and 8 pin sprocket, modded exhaust, high top cover with 562 air filter. My most used saw.
Does the bigger air filter make a good difference?
Its In your head I think . I have that set up . You can go a bit longer between cleanings though .
31 minutes ago, HuntingHicap said:
Agree with Stubby. However I think it helps the saw run a bit cooler, especially along with the muff mod. ( I have no scientific research to back this up!)
This is true . The very latest high top cover on the new 562 saws has a series of slots in the cover to help with the cooling .
