Hi All,
 Sorry, I've done this a bit back to front. I've milled all the Oak I have.
It's stickered and I've put on the first coat of PVA to seal.
I'm ready to lay it up but before I do wanted to be sure I had my timings right.
They'll be stacked out of direct light, moderate to good air flow.
How long to dry to a point I can work them without fear of further warping/splitting...   A year? Longer?
If it's longer I'm going to have to reconsider where I put them...that's my question really.
Many thanks  Bob
Hi the first thing I would do is remove the bark there is an ugly wood boaring beetle that loves oak bark and sapwood ,and the general rule of thumb is an inch a year plus a year so 3 yrs for a 2 inch board but depending on what you want to make a shorter drying time may work
As Gobby says about the bark.
However the 1" a year is commonly mistaken to mean the thickness of the piece.
It's from the centre of the piece.
So a 4" piece would take minimum 2 years in perfect conditions.
[emoji106]
2 hours ago, trigger_andy said:
10%? Even outside?
I can't see this myself, down here it would settle out at 10% at the end of summer or inside the house but unheated it would gain to a bit less than17% wwb.
Also I'd want to see a better support than shown, a block under each line of stickers and more weight on the top
