I have had a recent discussion with a TO who took great umbrage for my justification to first remove and later at their request reduce a tree... They felt that my use of the word hazardous was completely unacceptable and that I should not have used it. Their argument was that the council would only listen to a justification that was inline with their tree policy, which basically says trees can only be pruned if Dead, Dying, Dangerous or causing damage..
How can that be reasonable in an urban environment?  How else can I justify works to a basically healthy tree that is just too big for its location...?
The 20m tall twin stem ash tree in a 10m long garden overhanging a bungalow..
This was my Justification:
The tree completely dominates the garden (see aerial photo) and is the wrong species for the location.
The tree causes considerable mess, with leaf fall, sap and bird excrement making sitting in the garden if not dangerous, hazardous.
The tree has twin limbs at approx 3m. This compression fork is an inherent point of weakness and failure at this point would lead to to significant damage to the surrounding properties.  The council has indicated that it will not agree removing the tree therefore the reduction has been proposed as a compromise.
its not reasonable. Sometimes the stance of local authorities can be a bit much.
I probably wouldn't have used the leaves making a mess as any kind of justification though, ever.
Surely this statement relates to pruning of LA owned trees given increasingly diminishing budgets and hence doing the minimum perhaps to meet their 'DoC' responsibilities.
I would have thought that was the case..
They have really wound me up now as 13 weeks ago I put in an application to fell. 5 weeks later the council suggested they would not give consent but I should withdraw the application and apply to reduce..
Personally I thought this was a stupid idea as its a leggy 20m ash. The client wanted something however.  I assumed doing as recomended by the lpa I would get consent in the 3 remaining weeks.. But no.. the lpa decided that they would restart the clock.. 8 weeks later and still no consent so I chase only to finally get a refusal to reduce.
Edited by benedmonds
What did you put down spec wise to reduce in the end?
All I can see is its a daft tree to retain in such a small space. Also there are plenty of other tree's in the area by the looks of the print screen and it wouldn't be a huge loss to visual amenity.
Long term need multiple reductions, still cause same issues for the customer, possibly get ash die back at some point. I see it as throwing good money at bad and why should the customer have to pay hundreds each time to reduce for something of little benefit to them?.... Imagine if the customers had to endure the councils decision for the next 10 years then be allowed to remove the tree, why not let them have it out now and plant a better suited tree that in those 10 years could have grown to be a decent tree for the environment area and for amenity and worth of a tpo.
Sounds like your T.O cant see past the end of his nose
Edited by swinny
The council withdrew the initial application to fell when they told me to change the application to a reduce... I have asked for them to reinstate it and refuse it so | can appeal...  Hopefully they won't prolong the process by another 8 weeks by making me reapply.....
The client really doesn't have the resources to undertake the works and is definitely not willing to pay for the appeal. I have found this regularly happens when you tell them  it will take a year and you can't be sure of the outcome...  I could do and do sometimes make appeals without charging the client but it's all my time and I have already wasted enough with the first 2 applications and chasing for decisions...
Reduce by 2m.... Pointless I agree but the client wanted something done.
