God these tech-lite bars are made of cheese! Absolute rubbish.
Anyone got any ideas on what I can replace it with that might last a bit longer?
TIA.
Edited by Mick Dempsey
The original Husky low pro bar . Heavier but does not de laminate like the Techshite  . Or of course there are the 2 Jap offerings .
Mind it needs a different sprocket.  I like this bar and chain on the 2511 so thought I'd try on the husky
Have you lost much cutting speed with the pitch change? Would be nicer for pruning I bet.
Run a Sugi on a 540 and although the bar will probably last a life time the nose sprockets will not , got about 2 weeks from the original so although it’s a big outlay I would get a spare nose sprocket with a new bar just incase if you go sugi and then you could of brought 2-3 techlites.
