Does anyone know of a way of working out the weight of trees, I found one
on the web but convinced it's accurate.
Thanks in advance
So where’s the link, and how is it thought to be accurate?
I’d be very interested in this.
I use a simple system.
A cube 10cm each side is a kilo.
Ergo a 60cm log 2m long is about a half ton (green).
I'm always 10-20% under weight.
(Towing)
[emoji106]
(Towing)
Is that for hard or softwood?
Works out at roughly 28kg per cu/ft.
If hoppus foot is the measurement of what a log is expected to produce taking into account 25% wastage, to work out the weight you'd have to add the 25% back on to get a more accurate figure, Yes!
With hoppus you just convert at full measure,.and convert per species.
Yes, about 27Hft/tonne for pine, a bit less for oak and beech and more for sycamore and ash and the other softwoods
