3 hours ago, organic guy said:
Great minds think alike, I was going to ask the same question!
I use the ladder on every pass. Find it’s quicker and easier. Keeps the mill on the same set up and just cut away. No Need to keep fiddling with dimensions. 👍
26 minutes ago, trigger_andy said:
Im thinking of selling mine.
WWW.CHAINSAWBARS.CO.UK
PM-60-GB64 New Panther Chainsaw Mill 60" with GB 64" Milling Bar .404 .063 180 drive links. The Professional's Choice In Chainsaw Mills.
if you were going to sell, what would you want for it? I have the 64" bar and chain already. Don't know if I need another 64" bar to be fair. I can PM you if you prefer.
I think the bar accounts for around 50% of the set-up cost so most likely not something for you as Id only be selling as a kit.
Yes the bar is a fair cost. Ok. No worries, if I come into some money after Christmas, I might have a rethink. 👍
Thought I would do a bit of Christmas bank holiday milling. Not a lot else going on. Finished off two more sections. One big section left to go of the Black Poplar.
Nothing exciting just slogging out a cut list of DF including a rake of 200x200 4.9s, cold and muddy underfoot but at least no rain. Good opportunity to try a few mods including a secondary supply set up I’ve fitted that allows external hyd supply to be plumbed in, worked really   really well giving flow and speed not shy of the 3 phase set ups, the brace fitted to the end of the arm and running on a linear bearing also went well. It can be removed in 2 mins if you need the extra 180mm width it stops you from using.
  • Like 10
