Planning on building a trailer for my little woodland mill over Christmas time. I want to keep the full capacity length wise (22’)but imagine the trailers going to be about 8-9m long in total. Anyone towed something like that before and was it manageable? I’ve seen a few drilling rigs around that must be that length and they look stable enough. Is there a restriction on how long you can go? Weight shouldn’t be a problem and I can lock the mill off at any point on the rails to get nose weight/balance correct. Was hoping single axle if I can keep the weight down enough.
It won’t do many miles, mainly for use in the yard rather loading and unloading one side only in the shed as I do now. But I want to keep mobility at the full length if possible.
You can have a longer trailer because most glider trailers are, there's a loop hole in the law regarding total length and weight of trailer and tow vehicle.
Yes for indivisible loads you can go longer.
There is still a max of 18m total length of vehicle & trailer.
If its a separate trailer with a "load" on it you also have the legal over hangs that are allowed.
How much depends on how you mark it.
You cant go heavier.
If the mill is bolted together in sections it might be hard to claim its an indivisible load.
Why not have the bulk of it fixed & then extend the bed on a fold out section?
I used to tow an over sized trailer that was an indivisible load as it was a one piece fiberglass molding.
1 minute ago, Big J said:
It was braked and it was single axle. About 1800kg I think. With the Woodland Mill it will be much lighter so it's unlikely you'll need brakes.
Assume I’ll need brakes for over 750kg, even if it’s a fixed load and effectively not just a trailer?
It’ll be mounted on a fully welded steel frame/chassis which I’ll either make as the bed and track for the mill or permanently attach the mill tracks to. Want the full length ready to go permanently really without messing about, otherwise I could just put the thing on my 16’ trailer and overhang.
so will running wheels be the width of the cutting head assembly, or are you planning to turn it 90* and fix it in place, otherwise your head will most likely be the widest part of the mill/trailer combination, meet a  lorry coming in the opposite direction and you might need some clean underwear.... just a thought from towing mills around country lanes for the past 20 odd years....
