35 minutes ago, eggsarascal said:
Would this chipper have an Alternator?
It will have a charging circuit of some sorts . Battery would go flat otherwise .
2 hours ago, slim reaper said:
Twin B&S engines are used on ride on mowers so may be worth looking in that direction for a battery
I got one from the scrapyard, it works..   not that the thing started mind, spent a couple of hrs this afternoon cleaning the fuel lines, got it started just as it was going dark..  just enough time to stuff a trailer load of brash through it though...
If its an 18hp twin v like the one on my chipper, it will have a magneto on the flywheel, and should produce 14.4 volts when running
There you go then . :001_smile:
No Alternator then...
A magneto is a form of alternator eggs yeah, but uses stationary magnets that when spun create pulses of alternating current to run the given electrical circuit / need.
They are two different things Ratty.
