Some years ago when I started milling (8+yrs) I found no real problem with a short bar i.e. 36" with my home made mill and then with my Logasol at that size then I moved upto a 60" bar on a 090 with the Logasol and found a bad "bow" downwards at first added a an extra steel tube across the frame and that was better but still not to my liking so re made my own mill and it was only ok. I was using just standard full chisel chain. Recently moved to a Panther double headed on 72" bar with Oregon Hyper skip chain and suprise I was getting a 5ish mm downward bow, did a little head scratching and started to play with the rakers and problem solved. Took them down a little more than I would have before.
Most of my milling is to ready a stem for a large band saw so finish and to a small degree a bow if not too much is not the end of the world but if I was cutting for a" finished" slab I would use two rails for the first cut side by side to give the most support, think of felling- a 2" thick wedge is like 2' at the top of the tree so 2mm bend on the mill rails will soon become a bigger problem adding in bar flex etc on a milling cut.
I'd also check the cutters are all close in length lefties compared to righties. Don't think this is the bother here but I have had it do funny things with uneven cutter length
  • 1 month later...
When milling with my 48" Bar I find I get a slight sag in the middle no matter what I do. So when the Mill is in contact with all 4 corners and everything is square and true I note the cross bar with the push handle has a slight gap of a few millimeters. Im not sure what causes this? I also thought the weight if the bar, or torque of the motor? i also thought inaccurately and uneven sharpening but Ive been using the Granberg precision grinder to good effect and its not helped.
Do you think it may be the weight of the power head as I have noticed a very slight bow and taking the weight off the power head solved it , just a thought
Cheers Mark
Cheers Mark
Ive tried this too as my 088 is a heavy old lump. In fact I have always done this as the Power Head really lifts up the other end of the mill.
