Etched stove glass
richardwale
My stove glass was etched, cloudy patches caused by fly ash embedded in the glass. Distorted the view, really annoying.
A wet cloth made it go away and then as soon as it dried the cloudy bit came back. I was told nothing could be done apart from replacing the expensive ceramic glass. But no, silicon carbide 400 grit wet and dry sandpaper from Halfords, £3. Brand new super clear glass. Works a treat.
I'll be trying that! I've got a few pieces of etched glass in the garage from when I've changed them over the years. It needs doing again so this could save me £70.
I also read that prolonged over heating can cause the glass to be etched. Sometimes I've come in and the wife has it running flat out like a raging inferno... so she's had the blame!
2 hours ago, richardwale said:
It works, a bit of elbow grease and clear glass. The grits go as high as 1500 so a super polish finish is available
And the rest....not that you'd need it
https://www.ebay.co.uk/itm/WET-AND-DRY-SANDPAPER-MIXED-Assorted-GRIT-2000-2500-3000-5000-7000-PACK-OF-5/263050894805?epid=8003922941&hash=item3d3f0e1dd5:g:qsEAAOSw1BlZS6xT
Well that's 2 hrs of my life I'm not getting back! [emoji23]
Didn't work for me unfortunately. I tried 400 grit wet and dry by hand, then in a sander, and also tried glass polishing powder (cerium oxide powder). Still hazy and looks worse if anything.
I think I'll stick to buying a new piece of glass every year! [emoji16]
Sorry it didn't work for you,  has previously wasted hours on different methods to try and get the glass back to being clear but this sandpaper worked a treat.
Iv'e always used fire ash on damp kitchen paper on my B & G infire 800 before lighting a fire. But every third or fourth log I wipe the inside (flame side) of the glass with 00 grade wire wool and never had a problem........... YET!!!!!! and this fires five years old now. You get a nice bright fire all night and a ball of wire wool the size of a fist lasts for most of a winter
