Reckon the 241 is probably the best of the bunch and will be a bit more punchier than the MS181etc, 346XPs are fab but scarce for good ones now. I guess a fair bit hinges on how much firewood you cut and how much you will miss the punch of the 028 but think it is worth spending a bit more and not regretting it after a few hours cutting.
The easy starts and these "Simple" chain adjusters are a but weekend warrior IMO, they exacerbate the possibility of failure IMO and the chain adjusters can be a sod to rebuild if they come apart!
1 hour ago, stihlmadasever said:
Please dont touch a 135...it will taint your opinion of husqvarna chainsaws...
I still like mine after all these years. I don't know what the problem is with people who call them.
MS 181. Any of these symptoms sound familiar.
1: Knock the handle and the throttle and choke linkage all jumps out.
2: E-clip disappears off the end of the choke shaft on carb, causing all sort of problems.
3: Oil hoses leak where they fit in the tank, making a mess. New hose will cure that for a while.
4: Bar clamp stud comes out with the bar and cover attached to it, if someone does it up slightly too tight.
5: Bar clamp stud sometimes strips out of the plastic housing that it's screwed into. There's a oversized stud available for this.
6: Had a few main bearing s where the cages have disintegrated and gone up the bore. (Not just limited to the 181).
Edited by lurkalot
brain fart
The problem is theyre crap.
Cheap build quality
Difficult to start
Starter coil has went half a dozen times
Guidebar is made of papermache
Poor power to weight ratio
I could go on but like i say
Crap- and nothing anyone will say will change my opinion
So the huskys I have access to are the shit ones
nobody is recommending a stihl
there is is a Tanaka 4501 18”
and an echo cs420 that have been recommended are these any good
Whereabouts in ireland are you? Irish forestry products in limerick are good to deal with, picked up a 395 husky €200 cheaper than main dealer. Good website too, irishforestryproducts.com
