Fairly new to this - I've been sent an enquiry for a single tree to stump grind, its approx. 5ft across by 1ft high Lime Tree but with some bricks in it ! Good Access etc. they want to go 1ft under ground level. I've got a Track remote Grinder. Thanks in Advance
Don't want to sound harsh, but how on earth do you find yourself with a remote controlled tracked grind, which is a fantastic tool to have!! and yet not know what to charge?:confused1:
have to agree with skyhuck, if its your own grinder then you should know what to charge as that's not an amateur piece of kit, if you mean you have access to such a machine then charge for a day and hope you get it done before dark:D
Grindings off site or left in situ?  And to echo the above, how do you have this grinder and not know what to charge?  I'd be looking for £600 if I could complete the task on my own within the day.
