I normally sharpen my Granberg ripping chain at 20` and 0` but in a moment of madness I have done all the cutters at 0`, is it worth redoing or will it still cut until I need to sharpen again..... Fool!!!! check sharpener setting next time!
Hi Lazarus,
Cut away with it as it is. It will actually produce a very clean finish, though slower to push through the log. Its a common angle for super hard and exotic woods. Change the angles back at the next sharpening if you need to. I go the other way with my lucas mill slabber, cutting for speed rather than finish, as my clients are paying by the hour ,and will then go on to a secondary finishing of the timber. My angles of choice are 20-25° .
Play with the angles and find what suits you and your most common timbers.
Nothings ever lost when milling
Shaun
22 minutes ago, skc101fc said:
Hi Lazarus,
Shaun
Do you vary hook angles as well?
No I leave hook angles alone and as spec. Mess about with them to any degree and you'll either get a dangerously snatchy chain or one which doesn't barely cut. Also accurate grinding of hook is so very much harder to judge/ measure accurately . Same with depth guages, I leave at spec for machine and chain. Milling chain lengths are expensive enough without amplifying the risk of chain breakage.
Also because I'm cutting so many different types of wood I have to find the best compromise or all rounder set up to achieve good production rates. If I was doing all one species it would be worthwhile tuning the parameters to get the very best performance:quality balance, plus I'd probably still need to keep a number of standard set up chains just for the odd jobs. -Starts to get really expensive then !
  • 1 year later...
37 minutes ago, trigger_andy said:
Are you guys taking 10 degree ripping chains and grinding/filing them to 0 degrees?
That's how I started the thread as I c0cked up setting the grinder so not by design.
