This sounds daft is yours 110 3.5 ton or one ten 3050kg body change
Just a thought as we have just put a new tipping body on ours with no problem carrying 1.5ton max
Mines a 3500kg 110 hi cap... it’s an ex environment agency one
Regardless of its plate weight if you have the hicap 3.5 ton springs then it should carry it. The 3050 and 3500 are essentially no different. The springs are uprated and the chassis slightly thicker on the 3.5 but it's the springs that carry the load.
Edited by Glenn321
It's a Defender, it will just drive like crap when it's well loaded, I have never owned one yet that didn't.
However, we have terrafirma 2" lift heavy duty rears, with the assisters fitted (I seem to remember we had to machine the assister spring seats down to get them to fit inside the terrafirma's), Boge shocks and 265/75/16 BFG AT's, front is set up as standard for the 3500kg version, it's a bloody uncomfortable ride when empty but don't drive too bad when loaded, we still get sway if we are loaded with high pallets though.
Edited by scraggs
thicker,  really?
