Husky 266 or 365
huskykev
365 is a brilliant saw, a bit on the heavy side, will pull 18" easy. 560xp would be the dogs danglies for 18" if you can stretch to it. bear in mind that the bars husky saws come with are made of cheese. 266 is very good saw but unless you are lucky they have all been worked very hard.
my 560 is only used occasionally and hasnt given any trouble. a friend runs 24" on his and reckons it pulls it well. 365 maybe slightly faster in big timber (if at all), but for everything else a 560 would run rings around the 365, and 560 is much lighter
