It does look a bit risky as you're hand gets closer to the chain. You wouldn't want to trip/fall towards it either....
I wonder if the lack of guarding is why it's not commonly available in the UK?
You're probably right there. Anyone seen these for sale on mainland Europe - possibly Italy?
I got an MS230 of a mate that had worn out anti-vibe rubbers after using something like "Screwfix item no. 5256D "
I think having the saw attached encourages people to force the saw through the job.
that's an accident waiting to happen !!!
much safer to use one of these ! stack all you small stuff on it first then put a larger one on top so it doesn't bounce the saw about once you start cutting or you can put a couple of bungee straps to hold it tight together !
I made something similar out of scrap timber a few years ago and found it's the quickest way to deal with small stuff. Used to stack all the undersize (sub 3" diameter) poles separate in the racks and scoop them up as the last load of the day with the forwarder and then whenever I had to let a wagon in I'd cut and fill the trailer while he was loading the wagon - typically it would take about 40 min to cut and fill the widetrack sankey til it was heaped.
I did have one of those portek saw hawses and didn't get on with it. Used to find the small, smooth barked poles would grab and spin. I'd rather take my chances with one of the ones the OP's looking at :001_smile:
Yeah I've had a few bits kick on me as well using a portek (especially on the last cut). Trouble is the way you hold the piece down with your left hand means your thumb is vulnerable if this happens and have sprained it a couple of times which is a pita. The rack system as previously mentioned is the business for small bits especially if you have a saw with a long bar.
Right
Looking for something like this - any ideas? What is it called? Where can I buy one? (Haven't got time or equipment to build one).
Ideally it would dismantle/flat pack - aluminium tubing etc.
Cheers
ps if you have used a small chipper you will know why one is needed!
Yes having owned a tractor pto chipper then hiring a small chipper away from home for a favour at my brother in laws. I lost the will to chip rapidly! Sent chipper back within an hour.
We have discussed sawhorses often over the years and also branch loggers. Which is an eastern. European concept with operates like a chipper but you get rough cut logs quite quickly.
Here's a couple of links to look at http://arbtalk.co.uk/forum/firewood-forum/33895-oregon-easycut-sawhorse-review.html
http://arbtalk.co.uk/forum/firewood-forum/20652-tr70-branch-logger-apf.html
Sent from my iPad using Arbtalk
