trailer lights issue
Badgerland
Earth would maybe affect all lights, maybe a chaffed indicator wire to socket earthing out.
What happens when hazards are put on.
Depends how it's wired. I've just installed a towbar on our car and used a dedicated wiring loom that plugs into the rear lights and draws it's own power source from behind a cigarette lighter in the boot. It's earthed separately and has it's own relay and fuse
Sent from my SM-G930F using Arbtalk mobile app
  • Replies 23
If the same happened with two different trailers, then it is clearly the truck which is at fault. The Earth is quite often the problem which is the white cable. Try and join this with a wire to a known good earth point on the vehicle and it may cure it. Otherwise, the RH indicator is the Green cable which may have a short circuit. Problems usually occur at termination points such as plugs of earth bonding points.
I should caveat that I grind tree stumps, but I also have a HND in electronic engineering!
SG
Same thing happens with the hazards as the indicators. As soon as I plug in trailer lights I lose the indicators and hazards on the truck. Unplug it and all returns to normal.
Right hand indicator is along side earth in socket maybe some corrosion bridging the two.:thumbup:
Ah, that's a bit more useful information! Your vehicle should have an audible relay which 'beeps' with your indicators/hazard lights and is common to both with a trailer fitted. Check that for open cct or broken wires. Short cct's normally blow fuses!
SG
