6 minutes ago, Mick Dempsey said:
How heavy is a grain sack of logs?
I’ve run a 750 with a flail, wouldn’t really want anything smaller for that job.
If the dealer is close to you, and he has a good rep, go for it.
Multione is a very similar machine (I’ve had 3 of them)
I've ever weighed one, maybe a sack is 300kg? Avant say they can lift 800kg, but I'm concerned that the height and reach looks pants. I'm used to a full sized Manitou that can lift 3000kg nearly 7 meters.
Thanks, I will look at Mulitone.
my 520 will lift to 2.8m
don't forget they have an extendable boom
Thanks. Have you ever stacked grain sacks in two layers with it? I put pallets in the middle to provide more stability.
5 hours ago, Muddy42 said:
I appreciate I am picking up a very old thread here.  I am consider a medium sized loader, its main requirements will be:
1) stack grain sacks of logs, two high one on top of the other.
2) have enough pump power to drive a front mounted grass cutting flail for large areas of 'twice a year' rough grass cutting.
I am currently considering an Avant 500 or 700, because we have a local dealer that will offer a 5 year guarantee.
Are there any alternatives I should consider or feedback I should receive regarding the tasks above?
Thanks in advance.
You’ll need a large loader with a decent hp engine (read: expensive model with all the emissions bollocks) to do that.
I’d buy a loader to suit what you want to lift, and then spend what you would have spent on the expensive Avant flail on a secondhand compact tractor and flail. Much more efficient being pto drive. I don’t run any attachments save a grab and sweeper on my loader.
It'll lift an ibc of green logs at full height and reach. Which is around 380kg
Thank you
decisions decisions.  I currently have an ageing full sized Manitou, which is f-ing brilliant as a loader, but the repairs are starting to get expensive.  Clearly it won't run a flail.  I was hoping to replace it with something new and smaller (25-50hp) that could also run a flail.  Maybe it would be unrealistic to have a one size-fits all.
Sell the manitou, buy a small compact tractor with some creature comforts and a small rough terrain forklift.
Got myself an old Ausa C11, 1.2ton capacity. 900cc engine Vs using the 4000cc tractor loader, it's a no brainer with red at 93p a litre.
I’m not sure if avants or multi one offer this, but using a finger bar mower on a multi one 7 series was only ok at best, every time you turn, adjust the boom etc it saps power from the attachment, would be handy having a dedicated pump running the attachment line?
do you need to transport it on a trailer? Or is it gonna be at the Same place most of the time?
