  • Replies 22
Dynema with a fishing line core is some thing you have to try.. nothing else will do now.
Where did you get it from?
Sent from my SM-A300FU using Tapatalk
Stiffline by french touch concept! Its a stone cold killer but it does kink if left folded up. So just spin your cubes flat into a square rather that folding them up fully into a triangle. Or get some of the circular pop up containers :)
Looks very good Matty! Super strong at 150kg breaking strain...
Would say it's a bit stronger than the stiff line the only down side is you have to stretch it once off the spool so needs a bit of prep before use.. usually just tie one end to a gate unspool and go for a walk and wrap a stick around and pull as tight as you can ! If any one has an easier way please share as I need to replace soon as the current Iines been in the cube over a year and getting a bit short.
  • 2 years later...
Where did you get those circular containers Ben?
