Sign in to follow this
simonm
vandal prof fence
I have a fence to erect that runs along the side of a footpath that is frequented by scum bags! the fence that is currently in has being kicked to pieces and set on fire! other than palisade or mesh what other options is there? customer has asked if we can just use gravel boards but as its going to be 6' 6" high and its 190 feet long it will look horrible and cost a fortune...ideas :confused1:
Share this post
Link to post
How about electrified barbed wire,3 phase 415v of course?:biggrin:
I had thought about gun towers and an armed patrol but was afraid it was ott.
Share this post
Link to post
Metal panel fencing, costs a fortune so I'm told. In this situation I think the concrete gravel boards in slotted posts is the best option, fence for life as well.
Share this post
Link to post
Its customers fence, cant plant owt behind as it will get wrecked, everything that's solid is industrial. Thought about double gravel board on bottom to make it awkward to kick then like verti lap panel but on the reverse butt boards up together and fix on. Will never get kicked through.
Share this post
Link to post
Verti lap panel? not sure what they are, but if they are made of wood, didn't you say they set fire to the fence?
Share this post
Link to post
Palisade, Vmex panels (standard or prison type), weld mesh or expanded mesh are all options.
Also consider plastic slotted posts and plastic 300mm gravel boards. Its amazingly strong, I have it at home.
you can put upa wooden fence and stitch weldmesh to it to stop them kicking it in, it worked for a customer of mine
Share this post
Link to post
Tried the full gravel board type and they still managed to kick them to pieces. After I had replaced them for the 4th time I think they got bored. I got paid each time for my work but it was a pita
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
