Using a Winch
sargan
  • Replies 59
8 inches...
How long you got to get em out?... if you want to get em out cheap, an axe, a trench spade and a farm jack... maybe a couple of pry bars..
Get about ten out then take a break till you fancy doin some more..... won't take long once you get stuck in.....
As to where the stumps are goin, I expect the same place as the rest of the tree's....
80 stumps ??? Turfer, mini diggers, hand tools, !!!
Times money get a stump grinder in and grind em, job done in a day with one opp if site needs to clean you've only got one truck load of shavings
Start digging or pulling them out you'll have 4 truck loads of crap to despose off
OK .. I'll give a bit more detail.
The row of Leylandii is on a bank raised about 5' from ground level ... brick wall to front bank behind.
The top of the bank is approximately flat for the staggered row of Leylandii, then it slopes off at about 30 degrees down to a field ... mature mixed species trees all along this 'slope'.
No real option of getting a digger in.
The guy I had look at it advised it was easy enough to get his walk along tracked stump grinder up onto bank using some ramps .. then no problem working along the bank.
He advised tracked machine as in pic attached - can these be hired easy enough?
